Van, on those one barrell carb tractors its sort of typical at slow idle if you pulled the clutch pulley side plug wire you wont notice too bad of a running difference, while if you pulled the flywheel side plug wire she will run terrible n almost die, but under a load and at RPM BOTH sides contribute more equal. When the plugs develop that flat black colored powdery sooty coating thats indicative of excess unburned fuel (running too rich, maybe an inlet air or air filter or choke restriction or a weak spark can cause similar problems as the fuels not getting burned up properly??) Things that can help reduce that are not running the carb any richer then is necessary (try to lean (screw in) the carbs top Load and Idle needles a tad n see how she does,,,,, ,,,,,making sure the choke butterfly plate is opening n staying full open,,,,, ,,,,make sure the air cleaner mesh and its lower bowl and the inlet pipes are all clean n free,,,,, ,,,,,avoid long idle periods,,,,, ,,,use shutters or radiator restrictiosn to get her up n stay up to 180 degrees or more,,,,, ,,,run a heat range or two HOTTER plug then specified (try an Autolite 3116 if 18mm plugs or a 3077 if 7/8 plugs),,,,, ,,,,, Use wire core NOT carbon suppressor type plug wires,,,,, ,,set the run timing a tad on the slow side,,,,, ,,,have the points gapped proper and have them clean n smooth and replace if burned or pitted or carboned up, YOU GOTTA HAVE A GOOD STRONG BLUE SPARK !!!!! !! A good hot blue spark on hotter plugs and get n keep her up over 180 degrees and dont run her over rich avoiding long idles ought to help the problem. If shes low on compression and/or an oil burner exhibiting blue smoke out the stack or excess crankcase blow by that tends to oil foul the plugs but that leaves more of a wet shiny uneven coating on the plugs. Dont run higher then necesary octane gas either and make sure its clean n fresh n water free but get her up to 180 and over. John T
