52' B engine questions?
Luke S
12-27-2005 09:57:49
Ok, I have a 52 B that we left sit for about 8 or 9 years. It locked up. Pulled it into the shop about a year ago and started tearing it down. Soaked cylinders and after a day or so tried to turn the flywheel over by and and after a pretty good grunt on my part it broke free, so obviously it was not stuck that terribly bad. Anyhow, removed the head, pistons, and block, took them to the local machine shop and we found that the block was craked on the bottom and had been repaired with JB weld many years ago. It had held ever since we had it and it looks like it will continue to hold? Also, he says one cylinder is pited somewhat. Head is good and he rebuilt it. Piston's are good also. I made one real big mistake however. I have never torn into an engine in my life and I found these little shims between the rods and rod caps and thought, oh gee, these can't be important and threw them in the trash. Boy that was dumb. Anyhow, I want to get this thing back together enough to use for raking hay. I am wondering, should I try to hone the block and use it? Or get a new block? I am on a small budget for this project, very small. Also, how does one go about trying to re-shim the rod's bearing's for re-assembly? can I just get some new shim's and take some measurements off the crack with a micrometer and try to match that as best I can? Or something else? Remember, I am stupid, so try to explain this to me in english! Ok, those are my engine questions, now to the tranny. Back when we use to use this thing if you shifted too quickly into 4th gear something would get bound up and it was like the tranny would jam and the tractor would not move. We'd have to remove the shifter from the top of the tranny and do something(can't remember what) and we'd be on our way, what could cause this and how do I fix it? Last, I have a bull gear with one tooth missing, we ran it that way for years, will that hurt anything or do I need to replace a bull gear too? Oh, one ore thing, the axle seals leaked terrible when it was parked, how hard is that?
Leroy
12-27-2005 17:48:44
 Re: 52' B engine questions? in reply to Luke S, 12-27-2005 09:57:49
If you could get it loosend up enough to turn and come apart I do not see where those oits in the cylinder could ever haven gotten bad enough to cause problems with running. On my Kohler engine in a garden tractor When I rebuilt that engine I could not get it to hone smoth, parts of cylonder hone never touched, put new rings in and used it hard for 9 years till the old piston had the top break off and cylinder came out looking better than when I put the rings in so if the crack repair looks like it would hold I would just put it back together with new rings and for the bearings you don't even have to measure them, just put together and keep adding shims till the bearing turns free on the crankshaft, that was the way shops used to do it back in 20's to 40's
BushogPapa
12-28-2005 07:11:41
 Re: 52' B engine questions? in reply to Leroy, 12-27-2005 17:48:44
Well..the little problem of the shifting is gonna Bite you on the Butt..!! It is caused by broken Detent springs and worn detents... Sooner or later, it is going to slip into 2 gears at once and tear out ALL the transmission gears..( about $2,000.oo worth).. You had better forget using it until you can do all the repairs and have a nice one for a Lifetime....OK..??? That includes the Bull Gear, too..!!
Luke S
12-28-2005 06:53:44
Really that simple? Sounds kinda crude, but I guess it could work?
Mike M
12-27-2005 11:08:08
You have allready been without it for 9 years so you may as well let it sit a few more while you save up enough money to buy a service manual and parts to do it properly.
Luke S
12-27-2005 13:35:03
 Re: 52' B engine questions? in reply to Mike M, 12-27-2005 11:08:08
Wow, sorry to upset you! I have enough money to buy the manual's, I just meant I couldn't afford to drop 5g's on it right now. Bought a new disc mower this spring and spent a bunch on my big tractor and money is not as plentiful as it used to be. Just wanted to get this thing going good enough to rake with it, not do and expo quality restoration, although I may later when money allow's.
Mike M
12-27-2005 16:06:41
 Re: 52' B engine questions? in reply to Luke S, 12-27-2005 13:35:03
You didn't upset me. I suspect I upset you ? But almost every answer you requested is in even an I&T manual. A JD dealer should be able to order you a new set of shims. Or call around some of the junk yards and get some used ones. Would even be a good idea to place a want ad over in the classifieds it's free and may even turn up some stuff. I have no problem helping people out and clarifying stuff,but it won't make much sense if you haven't studied the manual. All goes back to that feed a guy a fish he eats for a day,teach him to fish he eats for life thing.
Mike M
12-27-2005 15:44:23
If it's worth doing at all it's worth doing right ! Shouldn't be hard to find a used block and bull gear reasonable. Or pay a pro welder to weld the block and get rid of the JB. B parts are plentiful. If you can budget $500 you should be able to come close if you shop around.
