A powerblock
Matt Lane
12-26-2005 17:54:03
How much difference does a powerblock make on an 1950 A John Deere?
2 Cylinder
12-28-2005 09:56:12
 Re: A powerblock in reply to Matt Lane, 12-26-2005 17:54:03
I had a 47 JD-A that I tractorpulled with,I installed a powerblock in it. I also had the cold manifold, G carb. and some porting done on it. It turned 55 hp on the dyno. There are several JD-A"s that I know of with powerblocks, that don"t have the extra work done to them that are at, or just below 50 hp.
Duane Larson
12-26-2005 18:33:05
Matt,
Well, if you believe it, the 1967 Power Block advertising claims the PB adds between 18 and 23 hp for the A.
Leroy
12-27-2005 06:34:16
 Re: A powerblock in reply to Duane Larson, 12-26-2005 18:33:05
The 1963 TSC catalog listing says adds between 10 and 18 Horsepower by going from 5 1/2" bore 321 Cu In to 6" bore and 381 Cu In and raising compression to 6.5 to 1 and just the aluminum pistons in standard size says up to 25% more power and from 4.6 to 1 up to about 7 to 1 on gasoline or 8 to 1 on LP gas so I would think that 18 Horsepower figure would be for the all fuel tractor and the 10 horsepower would be for the gasoline tractor
Dane in PA
12-27-2005 04:42:56
Now when you say "if you believe it", do you believe that amount? I don't know much about the rebuilding part of tractors but I know I want more hp. I would have never guessed it would add that much. I would like to get a powerblock sometime for my '52 A, and believe me, if I can add 18-23 hp, I wouldn't be hesitating to get one.
Dane
