baker multi-valves
farmerboy
12-26-2005 16:35:16
I've been sort of looking for a baker multi-valve for my 1955 60. Came across one on an early styled parts "B" a while ago(this same "B" has a "diesel fuel only" sticker by it's fill cap - too bad the engine is gone. That'd be something unique if it had one of those conversion kits). This one is on a powerlift and I assumed it wouldn't work as my 60 has powertrol.
I just spoke with a gentleman who makes a living selling two banger parts and he was of the opinion they would interchange between powerlifts and powertrols. Will they?
If it doesn't work my 60's powertrol, will it work on my 1950 "B"'s powertrol?
430WLPG
12-27-2005 16:59:52
 Re: baker multi-valves in reply to farmerboy, 12-26-2005 16:35:16
they use the same bolts,as they just use extension bolts that are both male and female
CMB
12-27-2005 03:30:56
The power lift & power trol units ar generally interchangable for ABG-50,60,70. the bolt pattern is the same on all. If I remember correctly, when installing a Baker valve on a 50,60,70, there is a mechanical interference between the bottom of the valve & the power shaft shield fastener. Otherwise I think it would fit & work. Yes, any of them are a really "slick" outfit with a power trol valve body, & a Baker valve. That gives you the option of a position controlled rockshaft and a remote cylinder, or two remotes. It works even better on an A,B,or G when a live pump is installed between the governer housing & the Mag or Dist.
Stan - Florida
12-26-2005 17:30:02
Just curious as to why you would want a Baker Multi-Valve for a tractor that already has Powr-Trol? When we had a '43 B with Power Lift, I thought a Baker Multi-Valve would be a great addition so we could run a remote cylinder. Dad bought a new A in '49 and that took away some of the need for remote on the '43 B.
Just curious...I'm sure there's a lot I don't know about the Baker Multi-Valve or the Baker Control.
Stan
farmerboy
12-26-2005 18:11:05
 Re: baker multi-valves in reply to Stan - Florida, 12-26-2005 17:30:02
From my understanding, I can use the rockshaft as well as a cylinder, which would be nice for a wood splitter on a 3pt. or blade with power swing. Also, I could use two cylinders, which would be nice as well. Finally, it would be nice to just leave in the dummy plugs and use pioneer tips. No risk of losing them, no mess of switching them, etc.
There's also a lot I don't know about them. I'd like to learn.
Duane Larson
12-26-2005 18:23:58
 Re: baker multi-valves in reply to farmerboy, 12-26-2005 18:11:05
FWIW, I'll be covering Baker Controls and Baker Multi-Valves (along with power blocks, Heisler heads and manifolds, ..., and some really weird stuff) in a talk on aftermarket equipment for Deeres at the next Gathering of the Green winter get together. For info, www.gatheringofthegreen.com
farmerboy
12-26-2005 18:38:18
 Re: baker multi-valves in reply to Duane Larson, 12-26-2005 18:23:58
I had heard of the GOTG but never looked into it. With one post, you may have convinced me to go...
Duane Larson
12-26-2005 18:47:54
 Re: baker multi-valves in reply to farmerboy, 12-26-2005 18:38:18
I've been to all three and really enjoy them. The last one had about 1600 attendees from 36 states and some foreign countries. But if you need a motel room I would check pretty quickly as rooms go fast!
buickanddeere
12-26-2005 22:13:52
 Re: baker multi-valves in reply to Duane Larson, 12-26-2005 18:47:54
Canada is a foreign country?
F-I-T
12-27-2005 07:14:28
 Re: baker multi-valves in reply to buickanddeere, 12-26-2005 22:13:52
They sure do like to look at my passport when I fly up there, so I think of it as a foreign country.
Frank
buickanddeere
12-27-2005 12:59:03
 Re: baker multi-valves in reply to F-I-T, 12-27-2005 07:14:28
F.I.T you have been to Canada and didn't drop in for a visit?
F-I-T
12-27-2005 19:48:10
 Re: baker multi-valves in reply to buickanddeere, 12-27-2005 12:59:03
Yes, I spent from July through October 2001 in Ottawa and from November 2001 through January 2002 in Toronto.
Frank
buickanddeere
12-28-2005 21:11:19
 Re: baker multi-valves in reply to F-I-T, 12-27-2005 19:48:10
"November 2001 through January 2002 in Toronto". I was living in Newcastle and working at Pickering at the time. On days off I drove west through Toronto, right to the east coast of Lake Huron.
steve from mo - dangit!
12-27-2005 08:11:01
 Canada is not the USA. in reply to F-I-T, 12-27-2005 07:14:28
Not quite, anyhow. Fine people up there, but customs at the border (both sides) are pretty fussy.
US Customs can be really nice to really hateful depending on the day, their outlook, and your attitude.
I haven't had much problem with Canadian Customs except when they asked me if I owned guns. I said yes, so they searched all my bags just in case.
Leroy
12-26-2005 17:04:51
B to B should work as all B's could use the same hydrolic control but not on 60 because that would be a different size the same as the A's hydrolic, bigger for bigger tractor
Duane Larson
12-26-2005 17:36:19
 Re: baker multi-valves in reply to Leroy, 12-26-2005 17:04:51
farmerboy,
A November 1951 piece of Baker MultiValve advertising I have notes the B950-100 unit is "for John Deere A-B-G-GM-AR tractors (with power lift or powr trol) 1937 and up".
They were also sold by Tractor Supply Company, and their 1956 catalog lists one unit for the A,B,G,GM, another unit for the AR-AO, and a third unit for the 50-60-70.
A separate device, the Baker Control, worked with the power lift system to give the same level of control over the rock shaft arm as the powr-trol unit.
So, as LeRoy noted, the unit you found will work with your B but not your 50.
farmerboy
12-26-2005 18:26:45
 Re: baker multi-valves in reply to Duane Larson, 12-26-2005 17:36:19
Thanks for your info Duane and Leroy.
Would you be able to scan that info, Duane? I found the article out of the June 1997 GM. Is this what you have as well?
So a Baker will work on either powertrol or powerlift? It's unfortunate I couldn't use it on my "big" tractor, but if his price is right, I might still get it for my B. From searches on this site, it seems it's a matter of draining the oil, unbolting the unit, and bolting this unit between the powertrol and the PTO housing with longer bolts, right?
Duane Larson
12-26-2005 18:43:10
 Re: baker multi-valves in reply to farmerboy, 12-26-2005 18:26:45
Yes, I have that article also by Greg, but what I was referring to is a piece of Baker advertising I have. Probably about the same as in the article. Send me an email at [email protected] and we'll go from there.
