Stuck Bolts!!!!!
AB
11-14-1999 19:57:26
I have two 1/2 inch square-head bolts in my tractor frame that are stuck. I have tried turning the bolts, Kroil, trying to hammer the bolt back out.. all the usual things that usually work are just not working this time..any suggestions...Thanks
Bob
11-14-1999 21:40:36
 Re: Stuck Bolts!!!!! in reply to AB, 11-14-1999 19:57:26
heat them up red hot and pour cold water on then. you will be able to take them out with your fingers
Tugboat
11-15-1999 05:33:09
 Re: Re: Stuck Bolts!!!!! in reply to Bob, 11-14-1999 21:40:36
This sounds interesting. Does this Red Hot / Cold water trick really work? This could save a guy a lot of grief over the long haul! Tugboat
mark
11-15-1999 10:20:18
 Re: Re: Re: Stuck Bolts!!!!! in reply to Tugboat, 11-15-1999 05:33:09
yes the red hot bolt and cold water really does work. I use this method all the time with very good sucess.
mike
11-15-1999 11:15:16
 Re: Re: Re: Re: Stuck Bolts!!!!! in reply to mark, 11-15-1999 10:20:18
When only the head of bolt is showing does this still work? Ihave had similar luck with pulling this trick on frozen nuts
