JD hydraulic pump
Keith-OR
12-25-2005 20:57:04
I took Hydreco pump off of a piece of JD equipment, have no idea what it was as all I found was this pump hooked to a broken piece JD green. Manufacture by Hydreco User Mod. #AP22804, manufacture Mod.#150702211C1. Anyone have any info on this hydraukic pump....Thanks
Keith
JDG
12-27-2005 20:07:33
 Re: JD hydraulic pump in reply to Keith-OR, 12-25-2005 20:57:04
No index just tell what a part # fits.
JDG
12-26-2005 20:05:39
Part # AP22804 is not in master parts index. AP22804H is index and was used on combine #55&55H. Hope this helps.
Keith-OR
12-26-2005 22:11:51
 Re: JD hydraulic pump in reply to JDG, 12-26-2005 20:05:39
Thanks JDG, I think you are right, I probably missed the H suffex. There was a JD combine in the salvage yard. Is there any info on volume and pressure of this pump? I have to go back tomorrow to look for a spool valve will, check out that combine will I am there...Thanks again.
Keith
Glen in TX
12-26-2005 15:13:32
You might have someone run that AP # through a master parts index? It comes up invalid at JD parts site.
