620 valve adjustment
jdjack
12-25-2005 15:13:51
I need to adjust the valves on my 620.
what are the factory spec? And has anybody adjusted them to there own spec and had better performance.
buickanddeere
12-26-2005 15:43:40
 Re: 620 valve adjustment in reply to jdjack, 12-25-2005 15:13:51
A feeler gauge only works if the tappet face and the valve tip is perfectly flat and square. Otherwise everybody is standing around wondering why the valve train is so noisy after it was "perfectly adjusted". Loss of power too.
Kevin L.
12-25-2005 17:34:20
a 60 is .022 cold and .020 warm. if they wore they will be hard to got a good feeler gauge feel. there is a take the slack out of the rocker and backoff in the counterclock direction but can"t remember the back rate.
popper dick
12-25-2005 17:27:07
jdjack,
I just adjusted 620 valves this week. My JD manual calls for twenty two thousands cold. I have not started it up yet but plan to this week. Three of mine were out quite a bit.
Good Luck
Dick
