4010 throttle response
Corky
12-24-2005 21:25:48
My 4010 hand throttle doesn"t seem to control the engine speed correctly. One can move the throttle in either direction and the engine doesn"t respond accordingly. The engine may also speed up or slow down without moving the lever. The lever can be pulled up or pushed in, but that doesn"t do anything. Does this sound normal?
Thanks
New-Gen
12-25-2005 06:16:24
 Re: 4010 throttle response in reply to Corky, 12-24-2005 21:25:48
Sounds like the governor ring in the pump is bad. Not really that big a deal but while you're at it you might as well just spring for a rebuilt pump. Although you might be able to find a mechanic who can just fix the problem itself without going all the way through the pump, as long as it runs ok otherwise. Depends on how much you use the tractor.
Another thought...you don't use low sulphur fuel do you? I had problems with both a 4020 and 4320, there isn't enough lubricity in it.
corky
12-25-2005 11:47:24
 Re: 4010 throttle response in reply to New-Gen, 12-25-2005 06:16:24
Sorry, I forgot to say this 4010 is a gas burner.
