J D A Piston clearence
lencollings
12-24-2005 06:20:20
On a 47 A With .045 Aluminimum pistons the clearence betweed the piston and the cylinder wall is .042 on left and right and .043 on both top and bottom. As I recall the clearence should be .009 to .015. Does anyone know the exact value?
Mike M
12-24-2005 10:09:17
 Re: J D A Piston clearence in reply to lencollings, 12-24-2005 06:20:20
If you have mics you measure the piston at the bottom of the skirt opposite way the piston pin is. You should get max. dia. there.
If you just use feeler gauges the tightest spot should be at the same place. Bottom of skirt 90* to pin. Your clearance will be a direct reading on the feeler gauges.
Greasy hands
12-24-2005 09:44:54
I don"t remember the skirt clearance, but the way you measure it is as follows. Put the piston in with no rings on it, slide a feeler gauge, get your reading, and divide it in half. That is your clearance.
ps: Merry Christmas
Drew
12-24-2005 06:37:35
Where on the piston are you measuring? The area around the ring pack should have about the clearence you describe. Try measuring 90* to the pin at the pin centerline and see if you dont get a # that jives better with the .009-.015" clearence.
