4020 D '69 steering question
Nylon
12-23-2005 23:58:03
I tried to fire up the diesel the other day on short heat. It cranks over great on the 12 volt convert but wouldnt fire. I tried turning the wheel trick to see if it made any difference. I didnt notice any variation in crank speed. The wheel seemed to turn easy then hit kinda hard like the brakes do when you pump them up. I put on the heat a bit longer and charged the batteries and fired right up real nice.
Today I noticed that my steering nob on the 3 spoke wheel isnt at 6 o clock when wheels are straight. More like 4:30. Anyone know what happened here? Is the steering wheel on splines? Did I just spin the wheel a bit under the nut or is there something relating to hydraulic in the steering.
Any info would be appreciated. John
JimKS
12-26-2005 13:42:38
 Re: 4020 D '69 steering question in reply to Nylon, 12-23-2005 23:58:03
Turn you wheels all the way in one direction, then the other, holding them at each end of their travel for several seconds. It'll re-center.
Bob
12-24-2005 06:04:06
There is no mechanical connection between the steering wheel and the front wheels... only hydraulic oil. So it is normal for the steering wheel to "wander" a bit due to normal leakage in the system.
Nothing to worry about, and completly normal!
Nylon
12-24-2005 16:32:19
 Re: 4020 D '69 steering question in reply to Bob, 12-24-2005 06:04:06
Thanks Bob,
I was worried I got something important, expensive and a lot of work to fix out of whack. Feel much better now :]
John
