Bent JD H PTO
Trigg
12-22-2005 13:29:08
My "Basket Case" '41 H has an 1 1/8 pto shaft. It is slightly bent where it comes out of the bearings. Anyone think this could be straightened? I can't seem to find a replacement 1 1/8 shaft.
Ravgardner
12-23-2005 05:02:24
 Re: Bent JD H PTO in reply to Trigg, 12-22-2005 13:29:08
Tigg, This is interesting, my 42 H had a bent PTO shaft too. I found a used one at Sharps, Dave Cook and Lindstroms are great to work with too. I think I hava a theory about the bent shaft. The draw bar assembly was damaged. I think the four bolts hoding it in place lossened and separted from the tractor while it was towing a pto driven implement. This put a big stress on the little 1 1/8 shaft. Just a theory. I had to do some welding and rebuiding of the draw bar frame to get it back in shape. Good luck. I'm sure you will find a spare shaft. check out the story and pictures here:
leon
12-22-2005 17:51:03
Which reminds me, I saw a very, very, very nicely restored HWH sell in the $30 to $35K range last summer. It had a 1 3/8" shaft. What do you suppose the story was on that shaft?
F-I-T
12-23-2005 19:11:01
 Re: Bent JD H PTO in reply to leon, 12-22-2005 17:51:03
I think they went to the "standard" 1 3/8 shaft in the late models (After 47796?). I'm going to install a PTO in my '41 "H" and I bought a 1 3/8" shaft and fittings so I can use it on my dynamometer. And, if I decide to drag a finish mower around with it it's just one last thing to have to put an adapter on.
Frank
Larry806
12-22-2005 16:09:49
I"ve got a extra one laying in the shop now I"m pretty sure its 1 1/8 I can check it you want me to
Trigg
12-22-2005 16:17:56
 Re: Bent JD H PTO in reply to Larry806, 12-22-2005 16:09:49
If you would please Larry I would really appreciate it. Let me know what you want for it and I will see if i can pry the cash out of the boss.
P Browning
12-22-2005 15:02:46
Give Charles Lindstrom a call, or Dave Cook.
(816) 232-5868 or (913) 365-5500 for Lindstrom
(715) 373-2092 for Dave Cook.
If you strike out, write me.
(PatB)
F-I-T
12-22-2005 13:46:14
Trigg:
I see them pop up on Ebay all the time. Keep a look out there. While you can probably get it straight enough to work.....it's probably a whole lot easier to just swap in a good one.
Frank
JD9295
12-22-2005 13:40:44
a GOOD machine shop MIGHT be able to get it true, but if its not!!!
I would keep looking for a replacement
