1120
Bill Ross
12-22-2005 11:46:42
I bought an 1120 JD and I am looking for manuals and specifications for it so I can do maintenance. Can anyone tell me about the 1120 and point me in the right direction for manuals
Bill Ross
12-22-2005 14:29:26
 Re: 1120 in reply to Bill Ross, 12-22-2005 11:46:42
From what I gather all 1020's and 1120 after the first two years of production were made in Manhiem Germany and are identical. For some reason Deere chose to call anything imported to a country other than the USA a 1120 while the USA version was called a 1020. I have not checked the engine numbers out yet.
cannonball
12-25-2005 04:41:04
 Re: 1120 in reply to Bill Ross, 12-22-2005 14:29:26
how about a 1520- 1530 john deere ..they had a 164 cu in engine...have nice day may god bless
Bill Ross
12-25-2005 08:38:58
 Re: 1120 in reply to cannonball, 12-25-2005 04:41:04
Upon further review. I have realized that the 1975 1120 is actually the last year of the models imported to Canada. It is indeed as Canonball sugests the same tractor as the US 1520. I was thrown off track in looking in JDParts.com because it treats the 1020 and the 1120 as the same tractor but it is referring to the overseas versions not the american 1020. Anyway, I really like the tractor. It has power steering and an Independent PTO. It appears all parts are supportd by John Deere once you get the right tractor called up. I'm actually using it as a replacement for my JD 950 to mow my grass. this is about the lightest AG tractor you can get and not tear up the yard.
jdemaris
12-22-2005 17:43:58
Yeah, there are a bunch of tractors that are all pretty close to being the same - 820, 830, 1020, 300 industrial, 1120, and a few more. There are some minor variations though. 820 and 830 had different hydraulics than the 1020. I also do not think any 820s or 830s were offered with gas engines - only the 152 diesels. 1020 came with gas or diesel and came with either a four or eight piston closed-center hydraulic pump. 300 industrial was available with the big US built 2.4 c.i. hydraulic pump. The 1120 had a different fuel-injection systems than the 1020 and 300. That's about the extent of my knowledge on the issue - except I think the 1120 has a slight bigger engine than the rest - a 164 c.i. instead of the 152. But - since you've got one, you should know better than me what engine you have.
Bill Ross
12-23-2005 07:19:02
 Re: 1120 in reply to jdemaris, 12-22-2005 17:43:58
I took a look at the engine. It is a 164 C/I. It has a roto diesel injection pump. From casting date on the side of the transmission it looks like this tractor is a very late model. It says 29-1-75 on the side of the tranny. I take this to mean 29 january 1975, which according to my books amke this the last year they made them in Germany.
jdemaris
12-23-2005 07:24:14
 Re: 1120 in reply to Bill Ross, 12-23-2005 07:19:02
Yeah - I though the 1120 had the bigger engine. Same engine was used in the Deere 350 crawlers just about when I left the dealership in the 80s. I can't remember if it was the 350C or 350D, but I remember being surprised at seeing the French engine from Saran, and the bigger 164 cubes. Now, Deere uses the 179 c.i. engine to replace all the three-cylinder diesels.
jdemaris
12-22-2005 13:43:03
I was just discussing 1120s with a friend of mine - trying to ascertain what country they were sold in - do you know? We never had access to them at the Deere dealerships I worked at. \ As I understand it, it is basically the same tractor as the Dubuque 1020 ag. tractor - but has a Saran/France built engine and the rest of the tractor Manheim/Germany built. I think the main difference from the 1020 is the fuel-injection pump is a CAV instead of RoosaMaster - and maybe the three cylinder engine is a 164 instead of a 152 cubic inch. Do you have the numbers off the engine? As far as manuals go, IT makes them for the 1020/1120 series. And, if you scroll down a bit - in this forum - there is guy trying to identify his tractor - and it sounds like it might be like yours. He was thinking he has a 1020, but his engine numbers match what the 1120 uses.
