ANOTHER NEWBIEQ
TEXASJ
12-21-2005 16:20:10
what does all fuel john deere mean???
DickD
12-22-2005 02:30:22
 Re: ANOTHER NEWBIEQ in reply to TEXASJ, 12-21-2005 16:20:10
These tractors would burn about anything. Occasionally when we ran out of distillate, and we needed to grind feed, or other mandatory chores, we used furnace fuel. The tractor would smoke some but ran fine.
Maark
12-21-2005 17:32:34
Forgot, Distilate was a cheaper fuel to buy at the time.
Maark
12-21-2005 17:04:36
All-fuel means that when the tractor was produced, it was made to burn either gasoline or distilate fuel. The tractor was started on gas,after it warmed up to operating temps by way of a shutter in front of the radiator, it was then switched over to a distilate fuel, much like a kerosene or low grade diesel mix. When a tractor was run on distilate it was wise to switch it over to gas before it was shut off. It would start easier afterwards. I once bought a 44A that the previous owner would mix 1/4 tank of gas to 3/4 tank of diesel fuel. It ran on that mixture very well.
TEXASJ
12-21-2005 17:10:56
 Re: ANOTHER NEWBIEQ in reply to Maark, 12-21-2005 17:04:36
wow, i did not know that.how did it generate enough heat to burn the diesel? thanks maarc for the knowledge!
JGC
12-23-2005 11:53:23
 Re: ANOTHER NEWBIEQ in reply to TEXASJ, 12-21-2005 17:10:56
TexasJ,
The distillate (or diesel fuel or kerosene) is ignited by the spark plug like gasoline, so while the engine has to be up to operating temperature to work properly, the fuel is not being ignited by the intense heat as it is in a true diesel engine. I have run diesel fuel and kerosene in my all-fuel "D". It runs well, but in parades and light work, the engine does not create enough heat to really burn these fuels completely. There was a lot of build-up on the head so I run it on gasoline all the time now. It is interesting to run them on these alternate fuels though!
Jon
JMS/MN
12-21-2005 17:30:55
Of the three- gas is the most volatile, then distillate, then diesel. The mix had enough gas in it to make the mix closer to distillate. Some people (especially those lacking good judgement) do the same thing with their Knipco heaters. RIP.
