1940 JD A restoration project
Dean Lydey
12-21-2005 14:53:14
Santa came early! My wife located a '40A Serial # 493833 for me to try my hand at an easy restoration. The tractor is in running order really needing a carb rebuild, new manifold and paint. It's an all fuel and I intend to run gas only. The existing manifold has (4) fasteners attaching it to the block and the part number looks like 2??8R. It has a broken ear where the exhaust pipe connects and needs to be replaced. I'm thinking about going with a gas manifold for a little more HP. Any help with what I need and where to look? I also need to rebuild the carb. It looks like a DLTX 2A. Is this a good carb number? Is there something that needs to happen with the carb rebuild with an eye on gas only operation?
Thanks,
Dean
P.S. Yes, I am blessed with an awesome wife.
DickD
12-22-2005 03:00:33
 Re: 1940 JD A restoration project in reply to Dean Lydey, 12-21-2005 14:53:14
Dean; Good Luck with your 40"A" project. The 39 and 40 "A" are in a class of their own. They have several parts that differ from all the others. I looked in my carburator book, and for tractors between 488000, and 498999, it shows a DLTX38, which is a thumb type choke, all fuel carb.
Walt in Jaxn Tn.
12-21-2005 19:39:11
The origional carb for that tractor would have been a DLTX-33, the DLTX-71 was a gasoline only carb available for the 1948-1952 "A" that burned gasoline only. The hot manifold part # is A 2383 R, the gasoline manifold # is A 3386 R, the gasoline manifolds are being reproduced and can be found here and on other sites for around $100, the hot manifolds aren't being reproduced so be careful with the hot manifold that you have, the ear that is broken can be repaired, someone might be needing that hot manifold someday, if that engine is stock, it has low compression pistons for burning low grade fuels also.Get a parts book for your "A" and be on the look out for spare parts, the parts book will let you know what parts from other tractors will fit your tractor. --Walt--
