HP Require. for JD 336 Baler
minkcreekfarm
12-21-2005 08:23:59
I'm trying to match a tractor with a 336 Baler.
How much HP does this baler require. Out of curiosity how much did an old 14T baler require
Thanks
Not very much
12-22-2005 17:58:33
 Re: HP Require. for JD 336 Baler in reply to minkcreekfarm, 12-21-2005 08:23:59
My father used a JD420T to pull a 14T Baler for some eight yhears until he bought a 3020 and he still occasionally used the 420 to bale with for years after that. We pulled the baler and a 4-5 ton haywagon behind it. The baler would certainly shake the tractor and it was obvious that a bigger tractor would work better---but the 420T (28hp) had enough power to do the job, even though 28hp supposedly wasn't enough. before we got our own baler, a neighbor used to bale for us using an old IHC45t and an 8N. That was one poor baling rig, but between breakdowns and field repairs (the 45T is the worst baler ever made) That 8N actually pulled the IHC baler too!
old
12-21-2005 13:41:35
I would believe a B wouldbe a little to small to pull a 14T been there done that and it didn't work. That said it was a 1935 B all fuel. An A will do it just fine but my self I prefer ones with live PTO makes it a lot nicer to run them and less hard on the tractor. Before I switched over to round bales I use an Oliver 77 to pull my 14T and it did real well.
BushogPapa
12-21-2005 11:09:51
30 to 35 HorsePower should be sufficient, provided it is real Horsepower.. A JD "B" or JD 530 runs them fine..on level ground.. On hilly ground, you will want a heavier tractor.
Ron..
