Fuel Bleed Plug
nmi720
12-21-2005 04:08:26
Hello all. On the flywheel side of a 720D you have you bleed plug that runs through the block and into the pump bracket. Is there a sealing washer that goes on the end of that plug where it meets up with the pump bracket or is there just the 1 on the outside....
NMI720
12-21-2005 12:08:01
 Re: Fuel Bleed Plug in reply to nmi720, 12-21-2005 04:08:26
THANK FOR THE HELP GUYS. I AM GLAD I ORDERED 2 OF THEM WASHERS
Kevin L.
12-21-2005 09:34:01
if we"re on the same page, the book shows an alum. washer inside and one outside with the same part number.
Kevin L.
12-21-2005 09:58:17
 Re: Fuel Bleed Plug in reply to Kevin L., 12-21-2005 09:34:01
went and looked at the parts book to see if I had over looked for differents for other serial number but show it for all serial 720D 730D, and does not show one under the cap part of the drill out bolt, only at the tip of the bolt and under the short bleed cap screw in the top of the bolt.
F-I-T
12-21-2005 11:56:50
 Re: Fuel Bleed Plug in reply to Kevin L., 12-21-2005 09:58:17
third party image
Kevin:
Those aluminum sealing washers were used up to the introduction of the self-bleeding circuit. After that on the 730's the drilled through bolt was discontinued. When used, there were only ever two aluminum washers. The "outside" shoulder of the pipe nipple or through-drilled bolt doesn't seal on anything. Just the nose of it seals in the pump. I had one out last week and the body of the bolt was covered in dust and rust, but the tip was clean as a pin.
Frank
