1950 John Deere B First Reduction Gear (weights)?
MACE
12-20-2005 17:35:32
third party image
As you can see in the picture, I have the outside half of one of the weights missing. I am guessing these are used for balancing of the gear. What should I do? Is this part of a weight I am missing? You can see the one at the 7 o'clock position. It has a type of round button head that has been rubbing on an indention on the inside of the cover assembly. And for some reason, I can also see a semi-circle outline of the gear on the inside of the cover/housing as well. Has anyone seen this before? The only part I have ordered is the smaller outside bearing that goes in the housing thus far.
Thanks,
MACE
Jason Z in MO
12-21-2005 13:01:00
 Re: 1950 John Deere B First Reduction Gear (weight in reply to MACE, 12-20-2005 17:35:32
MACE,
You might know this already but there are 3 bearings in the sliding gear shaft assembly.
1. Starting from the right side; the one you ordered which is in the 1st reduction gear cover. 2. The middle bearing slips inside the transmission drive shaft (the shaft the reduction gear mounts) and the sliding gear shaft stub end slides inside this bearing. 3. Then on the left side the sliding gear shaft is mounted to the main case with the 3rd bearing.
So there are 2 other bearings in question.
Mike M
12-21-2005 18:28:29
 Re: 1950 John Deere B First Reduction Gear (weight in reply to Jason Z in MO, 12-21-2005 13:01:00
4 total you forgot the one that the actual input shaft rides in.
Jason Z in MO
12-21-2005 20:30:20
 Re: 1950 John Deere B First Reduction Gear (weight in reply to Mike M, 12-21-2005 18:28:29
Caught me! Hope I didn't leave that one out... It will sure make a hellava racket when I first stick it in gear!
Mike M
12-21-2005 05:57:24
I think what you are refering to is just heavy round washers riveted in place. These act like a key so the gear doesn't spin on the cast center. The gear teeth is a seperate piece just press fitted on like a ring gear is. I guess your RH bearing is gone and hole wallowed out letting the gear ride where it isn't to be.
MACE
12-21-2005 12:13:37
 Re: 1950 John Deere B First Reduction Gear (weight in reply to Mike M, 12-21-2005 05:57:24
Thanks to all of you for your advice. I will have to check the left hand bearing and see what I find. The right hand bearing came in the mail today.
Kind Regards,
MACE
Merle Hoppenworth
12-21-2005 05:31:25
I don't believe what you are looking at is a balance weight. Put a new bearing in and check for proper spacers, the marks possibly came from pieces from the bearing running around in the cover.
BushogPapa
12-20-2005 21:05:23
Maybe the bearing was bad..?? I really doubt they wasted time and money on balancing the 1st reduction gear..!!! These are really low RPM engines... I think you should check that the bearing is drawn up nice and snug, when you put it all back together... If it is like my 630, the wobble in the shaft won't go away until the 1st reduction cover is on and the bearing is drawn up...
Ron..
