1945? A slant dash question
Dave in OK
12-20-2005 14:01:27
I have a Model A with slant dash. The steel sn tag is bad enough that I can only get 4540 off of it. The numbers before or after are gone. It has the PTO flipper cover, angle iron frame,DLTX53 carb,generator brkt is B2113R, gen pulley is B1030R,non pressure radiator,number on block in front of belt pulley is 250,mag is Wico C,6 speed tranny. Serial tag is definely steel, how late did they use steel? Thanks for any input.
Dave in OK
12-22-2005 16:35:07
 Re: 1945? A slant dash question in reply to Dave in OK, 12-20-2005 14:01:27
Thanks for the replies. I called the original owners Son, and he thinks it was bought in 45.
So I guess that some 1945 A"s had steel tags.
I think the number is missing the outer numbers or the first two. I may do some searchs thru the 2 cyl. club over the next few years. Hopefully I get the right one without having to do 10 or 20 searchs. I"ll have to join them to save money, heee.
Jason D. Wahl
12-21-2005 14:44:41
If it has a non-pressurized radiator then most likely it is a post-war tractor i.e. late 1945-early 1947. Mid '47 went to the pressed steel frame models. Slight chance it could also be a '41 model as this was the first full production year of the six-speed tranny which is why they had to 'slant' the dash to clear the hi-low range handle. 1942-44 had the cast iron 'belly pan' frames as I call them. Not many '42 models made.
donwisc
12-20-2005 18:02:42
If I understand your post correctly you can read the 4 middle numbers and cant read the first and last.
If this is the case the first number must be a 5 as a 4 would put it be fore the styled A. A 6 would make it a later styled B. Refer to the serial number page on the left.
Walt in Jaxn Tn.
12-21-2005 20:39:26
 Re: 1945? A slant dash question in reply to donwisc, 12-20-2005 18:02:42
third party image
Here's a photo of my 46 long hood "A" ser # tag, it's aluminum. the ser # is 568664, it has non pressure radiator (big cap) and angle iron frame (not cast iron) --Walt--
