#1. Not me unless there was but a single bolt holding the rear cover on the main case. Been 23 years since I last opened up the H but as I recall I put only the lowest bolt loosely in place, leaned the cover to the right and back a little, slid the front of the shaft through the cover & propped the front end atop the differential bull, set the cover straight, put in the rest o the cover bolts and then bolted up the shaft's rear bearing housing. #2. As I recall the obstruction was the bolt flange for the rear cover as the main case was cast. Then again if you look at it a bit differently, maybe it was the front PTO shaft bearing and bevel gear. I remember thiking if I had just removed them from the shaft & kept 'em in the shop, the shaft would slide right in! Kinda depends on how you view the situation as to what's in the way of what. I thought it a piece o cake compared to rolling a 70's differential out of the case. Could probably use a sawzall to cut away some of the metal 'round the left side of the hole in the cover. That could provide unlimited clearance for easy insertion of the assembled PTO shaft. Room for the trouble light too! No need to compromise the nicely sealed rear cover gasket this way! There's a guy here all the time trying to sell us his book on the H recommending we look at this paragraph or that paragraph. It probly would caution us to this dilemma if we "clicked" to the right place first. Sorry, I've never been to the site & can't recall it's address. Good luck and happy wrenchin! {:-)
