All Fuel
Mike S
12-20-2005 06:20:43
Since I have started looking to buy an old JD, I see ads that will list the model as an All Fuel. What does that mean? I presume it means it will run on lots of different things from gasoline to kerosene and anything in the middle or what? And if it does, how does it do it?
Thanks
mitchp
12-21-2005 11:38:37
 Re: All Fuel in reply to Mike S, 12-20-2005 06:20:43
And they do smell good running on kerosene, i set mine up to run on kerosene again, if you want to do it, best bet is to use the small tank for kero. and the big for gas, get back with me if you want to see the homemade system i did to switch between tanks so you don't have to mess with that pesky 3 way valve.
Chuck430C
12-21-2005 05:32:37
There are JD ads from back when the All Fuel models were being sold that shows that gas was $.12 gal and stove fuel (kero) was $.06 gal. What happened to the concept is that, even way back then, the oil companies caught on to the increase in kerosene usage, and upped the prices. There fore, by the mid 1950s, it was about a split to use either gas or kerosene.
I am still amazed at how the prices can be so high on diesel and kerosene, it is a by product that the oil companies would throw away. How can it cost more than gasoline unless they are just screwing us through supply & demand?
Mike S
12-21-2005 03:53:07
Thanks for the replies. So it is like the Fordsons in the 20s and 30s that had the two tanks and started on gas and switched to kerosene or tractor fuel after it got heated up good. All fuel basically meant two. In the army we had some trucks marked multifuel and they would burn just about anything, cooking oil, fuel oil, some diesel,etc.
BushogPapa
12-20-2005 21:21:14
Don't forget that Kerosene is Higher Priced than Gasoline anymore...!!! All-Fuel tractors have substantially LESS power than a straight "Gas" model.. A "Gas" JD "B" will work all day long on a moderate load on just ONE tank of gas..maybe less, and that tank only holds 14 gallons dry... I pulled a xmas tree planter 14 hours in low gear at an idle and only used 7 gallons of gas..! Unless you are just wanting to smell the kerosene burn, I would go with the Gas..!!
Ron..
G/MAN
12-20-2005 07:17:26
Yes, all-fuel tractors were designed to run on distillate, kerosene, tractor fuel and other "heavy" fuels, and do so efficienty. As Bob said, the had pretty low compression ratios - generally in the 4:1 range, and used exhaust manifolds designed to heat the intake air charge enough to vaporize the fuel and keep it in suspension. Curtains and shutters over the radiators were used to limit airflow and keep the engine sufficiently hot to burn the fuel well - around 200 degrees or so. The tractors also had a small gasoline tank for starting, as starting a cold engine on those fuels was basically impossible. You'd start on gasoline, run the engine until it was sufficiently hot to switch over, and then switch the valve to the main fuel tank. And you'd generally shut the fuel off to run the carburetor dry at shutdown, or drain it after shutdown, so you'd have gas in the bowl when starting it again. Earlier "D"s used water-injection to help control detonation under heavy loads and high engine temps, as the octane rating of these fuels was much lower than gasoline.
Bob
12-20-2005 07:03:40
Generally, "all fuel" means low compression, heated manifold, and a functioning radiator shutter.
