2030 bubbles
charlesmm
12-19-2005 23:20:19
Recently aquired a 2030 which has just had new liners and noticed bubbles in the coolant so I re-torqued the head to 110 lb's and this has reduced the bubbles to a barely noticable amount , maybe 1 every 10 secs or less. should I ignore it,keep an eye on it and hope carbon blocks the gap ? Retorque to 10 % or 20% over the spec ? go to the trouble of fitting a new Gasket ? any ideas? Tractor will be on light duties until the summer and then will work hard . T I A
ricedaddy
12-20-2005 16:27:51
 Re: 2030 bubbles in reply to charlesmm, 12-19-2005 23:20:19
Make sure your bolts are not bottoming out, did it have compression washers on it? I just did a ford 4000 that came out of vo-tech, not only did it have the wrong head gasket, they forgot the compression washers! also use bars leak.
Good luck
PJBROWN
12-20-2005 04:58:43
I thought you shouldn't reuse head bolts. I know with a lot of cars they will strech the bolt and they will loosen up if you reuse them. Maybe you don't have to use new bolts on JD heads.
ET
12-20-2005 04:25:37
You could try updating to the new style head bolts and retorque the head using the torque turn method. Also when the liners were set was the deck height checked?
