4020 coolant leak
Rick in Michiga
12-19-2005 10:36:06
I noticed my 4020 has a coolant leak at the rear of the engine. It appears to be coming out about 1/2 down from the top and somewhere at the rear where the engine mounts to the frame/tranny. I noticed the amount that leaked out was about 20-30 drops while it was running for about a half hour. Leak stops when engine is not running.
Are there freeze plugs there, and if so do I have to split the tractor to get to it/them?
I"m hoping it isn"t a head gasket leak - or worse yet, a cracked head. I pulled it inside yesterday and fired up the furnace in the garage so I can get a better look tonight.
Any ideas/thoughts?
donmyeil
12-19-2005 11:43:33
 Re: 4020 coolant leak in reply to Rick in Michigan, 12-19-2005 10:36:06
Look at the thermostat housing and the bypass lines. I would bet that is what is leaking. there arent any freeze plugs in the head. cold weather will make antifreeze leak when it otherwise wont. on
