3-pt hitch on JD 50
zwr
12-18-2005 15:09:42
I have a tricycle JD 50 which is fitted with items I understand amount to JD's early attempt at draft control for 3-pt mounted plows, etc. It's a mechanical affair, a pair of assemblies mounted to the axle housing and linked to the rocker arms, that works with the 800 style hitch. Just wondering--how common is the draft-control stuff? Any value aside from the hitch?
JDVan
12-18-2005 19:57:12
 Re: 3-pt hitch on JD 50 in reply to zwr, 12-18-2005 15:09:42
Sounds like you have the makings of an 801 Hitch.
For more info on the 800 series hitches see:
http://public.fotki.com/deanvp/hitches/jd/800_series-1/
Dan in Ohio
12-18-2005 15:42:11
zwr, It sounds like a 801 3pt hitch. John deere made three versions of the 800 series hitch. The 800, 800A, and 801. Only the 801 had the draft control arms(tortion attachment). It is getting hard to find these hitches in good condition and complete. Most are mismatched assemblies of pieces and missing parts. I have two 800A's and one 801. Have not really used the 801 much yet, but it is said that the tortion set up was not to effective.
