5020 Fuel Lift Pump
billybunter
12-18-2005 14:45:13
Hi
Should the fuel lift pump pull straight off once the two retaining nuts are removed. Mine apprears very reluctant to come off and I am concerned I damage it in some way.Does the pump of some other JD model fit?
Thanks
msb
12-18-2005 17:30:37
 Re: 5020 Fuel Lift Pump in reply to billybunter, 12-18-2005 14:45:13
Should pull right off.If the nuts have been overtightened then the bolt holes have probably been squeezed shut and will act like a bolt is still in it somewhere.Just wiggle it and pull. Not real sure,but I think the 3020 & 4020 used the same pump as well as the 4000,4320,4520,4620 and 6030
