Behlen Overdrive for John Deere B
Limpy
12-18-2005 11:26:09
Does anyone have a parts book for a Behlen overdrive for a JD 39 B or know what bearings it takes for the top and bottom shafts?
B A owner
12-18-2005 18:31:24
 Re: Behlen Overdrive for John Deere B in reply to Limpy, 12-18-2005 11:26:09
You can use the original Deere stock bearings . Just put one in a 38 B and got new bearings from Deere.
Limpy
12-19-2005 10:28:39
 Re: Behlen Overdrive for John Deere B in reply to B A owner, 12-18-2005 18:31:24
On our Behlen setup the bottom shaft bearings is the same. On the top shaft the bearing on the fly wheel side, the shaft is bigger. We have to figure out a different bearing. Thank you for your answer.
