730D flywheel adjustment
JDGMC
12-18-2005 07:05:02
I put in an earlier post but wasn't very specific on the subject line and didn't get any responses - so I'll try again. I was advised by an old pro that the fiber thurst washer may be shot because I've got about .125" of end play in the flywheel. I think he suspected that because that's about the thickness of the washer. He also suggested that its posssible that I may be able to just push the flywheel in. By reading the manual it would seem that the only adjustment is to tap the flywheel in to adjust it before tightening. When I looked at the locknut before anything was moved, it didn't appear that I would get that much ajustment from just this method, so I suspect something worse. It also doesn't seem that the lock nut will even go in any further. NOW, I've got the flywheel off but before I take anything else apart, I'd like to know if anyone thinks that one of these fiber thrust washers could be broken or just plain worn out. If so, how best to replace it???
Thanks again,
JDGMC
Carl NY
12-18-2005 09:36:04
 Re: 730D flywheel adjustment in reply to JDGMC, 12-18-2005 07:05:02
With that much side play, it sounds like the thrust washer - R1407R is worn or destroyed. You need to remove the the left side main bearing housing to change it.
Kevin L.
12-18-2005 18:36:32
 Re: 730D flywheel adjustment in reply to Carl NY, 12-18-2005 09:36:04
there two of the thrust washers, one not far behind the flywheel and the other inside where the connecting rod are. under the left lid under the starter or pony motor.
Kevin L.
12-18-2005 18:44:42
 Re: 730D flywheel adjustment in reply to Kevin L., 12-18-2005 18:36:32
you might drain the oil at both drain plugs and see what kind of parts are in the oil and also explore up in the drain hole with your finger to look for extra parts. I found parts of a govenor weight and piston skirt in mine. the lower drain under the flywheel does have gears in finger reach and both could have metal with sharp edges.
JDGMC
12-19-2005 16:25:22
 Re: 730D flywheel adjustment in reply to Kevin L., 12-18-2005 18:44:42
Thanks for the replies. I plan to take it apart tonight.
JDGMC
