JD 2010 Hydraulic System
jimjo2
12-18-2005 06:17:52
I just purchased a late model 2010 and everything worked fine during the test run. I put a rear scraper on it to clean my driveway, drove the tractor home (about 6 miles and all oil was warm), and by the time I got home I lost all hydraulics; power steering, 3-point and bucket loader. I let the tractor sit for about an hour, went back out and had limited power. Does anybody have any ideas? Hydraulic oil is full. I haven't checked filter yet. Is there any connection to this problem and the pump unloader valve? Is my pump shot or possibly the pressure relief valve?
JD man in SD
12-18-2005 08:22:01
 Re: JD 2010 Hydraulic System in reply to jimjo2, 12-18-2005 06:17:52
i would trans drain trans and pull filter it is a fine screen type if you find yellow primer paint chips in it the trans has had water inside if not clean it out and reinsall put in new oil
jimjo2
12-18-2005 13:06:10
 Re: JD 2010 Hydraulic System in reply to JD man in SD, 12-18-2005 08:22:01
Does the transmission and the hydraulic system share the same oil?
chrisfromsolitude
12-18-2005 13:27:18
 Re: JD 2010 Hydraulic System in reply to jimjo2, 12-18-2005 13:06:10
The hydraulic oil and trans. fluid are one and the same on that tractor. There is only one filter and if it gets clogged you loose everything. I would try changing the filter and I would bet it would fix your problem. Let us know how it turns out. Hope this helps and good luck.
chrisfromsolitude
12-18-2005 13:24:51
The hydraulic oil and trans. fluid are one and the same on that tractor. There is only one filter and if it gets clogged you loose everything. I would try changing the filter and I would bet it would fix your problem. Hope this helps.
jimjo2
12-23-2005 09:55:51
 Re: JD 2010 Hydraulic System in reply to chrisfromsolitude, 12-18-2005 13:24:51
chrisfromsolitude,
Thanks for the help! I drained the oil from the reservoir, flushed with 5 gal. diesel fuel amd refilled with new JD oil and new filter. The system appears to work normally. I am doins some other repairs right now so I haven't tried to work it yet but I think it look good. I am going to try to take a pressure reading somehow, do you have any advise?
jimjo2
01-27-2006 16:55:50
 Re: JD 2010 Hydraulic System in reply to jimjo2, 12-23-2005 09:55:51
chrisfromsolitude,
I finally got to use my 2010 today and the hydraulics seem to work fine. Thanks again for your help.
Jim
