3020 rocker shaft seals
Robert
11-14-1999 11:54:08
I have a 67 3020 . I have a problem with the seals on the rocker shaft that hold the 3-point hitch arms leaking. I use it for light field work and have to replace these seals about once a year. Causes and repair action appreciated.
Thanx guys!!!!!
JEFF W
11-17-1999 12:57:36
 Re: 3020 rocker shaft seals in reply to Robert, 11-14-1999 11:54:08
Link
Craig
11-15-1999 11:26:40
A repair shop here has the bushing modified to accept an O-ring like the later model tractors use. This is claimed to cure the leaking problem that is common with those tracotors.
mark
11-14-1999 15:26:15
i assume you mean the load shaft seal at the bottom of the rear end housing. have you replaced the bushings that the seal fit into? also when you have the shaft out, do you remove the rough edges and burrs off the shaft? or maybe you need to replace the shaft, as it might be worn at the bushings. there are also shims available to put between the housing and casting that holds the arms to prevent too much side play which also cause premature seal failure.
dave
11-14-1999 12:41:29
if your using jd parts the shaft and bushings should also be changed however this may not solve the problem i read an ad sometime ago where a company in the midwest was selling seals that would not leak
