2240 Reliability
Gibby
12-17-2005 20:42:34
I am looking at a 2240 and I was wondering if they have any special issues I need to be wary of?
PJBROWN
12-19-2005 04:47:47
 Re: 2240 Reliability in reply to Gibby, 12-17-2005 20:42:34
The 2240 is a great little tractor. Just make sure you wear ear protection if you run it all day. Them little 3 cylinders were loud, but ran like a top.
JDknut
12-18-2005 12:08:18
The Deere Mannheim 2240's are good tractors but you do have to watch for wet-sleeve pitting due to cavitation erosion/electrolysis. My 2350 MFWD (which has the four-cylinder version of the 2240 179 three cylinder engine) had this happen and it required an inframe. That said, the 3-cyl 179 like that used in the 2240 is a very good engine and is used to this day in the smaller 5000 series Deeres. When the wet-sleeves pit through, antifreeze gets into the oil and if you don't catch it in time, it wipes out the crank as well as the bearings. So check the engine oil for antifreeze. After the tractor has been setting for a while (the longer the better) remove the drain plug and drain out a tiny bit into a flat dish and hurry up and put the plug back in and then look for antifreeze in the oil that you drained out. You also might change out the oil filter and then cut open the old one and look for signs of antifreeze there. A little tiny bit of clear water might not be too bad if the tractor has been started and stopped a lot and not allowed to warm up in between, but there should be no antifreeze. Then again, antifreeze might only mean a head gasket or a leaky oil cooler, but I was not so lucky. If you find antifreeze, you can always check further to see if it is the sleeves. If the tractor checks out OK, and you buy it, change the antifreeze anyway just to be safe. Deere also has a coolant additive that helps prevent wet-sleeve pitting, too. All wet-sleeve engines can pit (IH's are famous for it) but some are more prone than others. Other than that, the 2240 and it's relatives are good reliable utility tractors with no other issues other than those any tractor can have. excuse the long post, hope this helps some and good luck.
Gibby
12-18-2005 12:51:26
 Re: 2240 Reliability in reply to JDknut, 12-18-2005 12:08:18
Thank you for your input, I will look closely at the oil.
Thanks
Dave
JDknut
12-19-2005 03:50:25
 Re: 2240 Reliability in reply to Gibby, 12-18-2005 12:51:26
Well, just wanted to give you a heads up. Good luck on that, hope it works out well for ya.
