48 d hits harder on #1
jas
12-17-2005 14:53:42
I have a 48 D with dual straight 4" stacks and when it's running you can hear #1 hit much harder and steadier than #2. If you put your hands on top of the exhaust pipes you can feel much more heat and a steady "beat" to the #1 side. If you pull plug wires while it's running, it will run on just #1 or #2. Again much easier and better if it's on #1 instead of #2. Is this normal? It's got plenty of compression and a new valve job. Also the mag will throw a hot spark at least a 1/2" maybe more if you pull the wires while running. Also pulled the champion w18 out of #2 and put in a new ac c77L with little change. Any thing else? I can"t imagine it's carb related as good as it sounds on #1 but...???
jas
12-18-2005 18:57:26
 Re: 48 d hits harder on #1 in reply to jas, 12-17-2005 14:53:42
I thought that the cycle might have something to do with it. I'm running the wico mag. Don't know which one. Haven't looked that close yet. Would like to post my Christmas card here for all my JD friends to see but don't know how. Could someone help? Thanks to all for the great info!!!
buickanddeere
12-18-2005 16:48:15
Harley Davidson bike engines run the same way.
BushogPapa
12-18-2005 14:44:04
When it is working hard, they should even out... The Left cylinder gets the fuel/air charge 1st and the Rt one starves until it is working hard enough to open the governors enough to feed the Rt one fully...
Ron..
John T
12-18-2005 06:23:46
Jas, we had a huge discussion on this a while back over on Johnny Popper and Frank n JR Hobbs weighed in to support what myself n Frank n several others plus Glen n all the good gents below all professed, that it was due to the 0 (No. 1 fires) then 180 (No. 2 fires) then a long 540 degree coast cycle before No 1 fires again that contributes to this when using a single barrell carb with a manifold thats common to both cylinders. It has to due with the fact that during the long 540 coast cycle residual fuel and vacuum in the manifold allows a better/more charge of gas to enter No 1 then No 2 at idle. JR Claimed the JD engineers acknowledged n were aware of that which is why they developed the 2 barrell carb so each cylinder had its own carb and manifold portion devoted solely to it.
ALSO that pop pop pop pop one hears a JD make IS NOT the No 1 then No 2 firing (That would be pop pop - - - - pop pop - - - - etc etc. The pop noise is THE ADDITION OF BOTH NO 1 AND NO 2. LIkewise, JR n Duane Larson n myself and manyyyyy y others way smarter then me discussed and professed and proved that by using mathematics and the sensitivy of the human ear to distinguish two pops over such a shorttttt ttt time i.e. the pop we hear is the addition of BOTH the 0 then 180 (an extremely SHORT time later) degree explosions.
Anywho, "Thats my Story n Im a stickin to it"
Fun discussion
John T
Glen in TX
12-17-2005 22:47:44
I agree it's just normal and more noticeable to you with the dual straight stacks. Go stand beside any old early D or GP manifold sometime and it will sound that way too. They do fire at 180 and 540. Are you running a Splitdorf CD2 or the special built Wico to fire on compression only? The other mags fire on compression and exhaust.
roger bultman
12-17-2005 19:28:39
I don't understand the explanation of phil2.
Isn't it the case that in a 4 cycle engine that the rotation for any cylinder is 90 degrees on the intake stroke with intake valve open and exhaust valve closed? If this is true, then regardless of the total rotation between 2 and 1 (or 1 and 2) the rotation on the intake stroke is equal for both. Thus there must be some other explanation or answer to this question why does this 48 d hit harder on 1 than 2.
Roger
phil2
12-17-2005 16:14:24
Normal. The flywheel rotation is 180 degrees between 1 & 2, and 540 degrees between 2 & 1. So #1 gets lots of time to pull in mixture and load the cylinder. Conversely, #2 is starved because it only has 180 to draw in a mixture. This is pronouced when the throttle plate is almost closed and the mixture must be pulled past it. Under load, the governor opens the throttle plate and the engine smoothes out.
Mike M
12-17-2005 15:08:57
Sounds like a normal 2 banger to me ! Put it on a good pull and it should steady out.
