Electrical Drain on 4020 Diesel Powershift
Princeton Bill
12-17-2005 12:02:52
I have a 1966 4020 Diesel Powershift. The tractor is currently at my brothers place. He has put new batteries and cables on it and she will start pretty good in this cold weather we have been having. However, if it sits for a day or two the batteries will rundown. There must be a short someplace, but he and his mechanic have not found it. It is still set up with the 24 volt starter and has a generator. Oh, they also put a new starter on it this fall.
My brother is thinking that there may be a short in the generator. Do any of you guys have any thoughts as to what it might be? Did those old girls have a notorious weak spot in the electrical system that could be causing the drawdown?
Thanks in advance for any information that you can come up with.
buckeye al
12-19-2005 14:58:22
 Re: Electrical Drain on 4020 Diesel Powershift in reply to Princeton Bill, 12-17-2005 12:02:52
I agree with Bob 'cause I been there.
It is surprising how quickly even a fairly large resistance to ground in the starter, generator or in the solenoid will drain a battery enough to make starting hard. Usually the fault is a path to ground in the starter & if memory serves me correctly, the right battery.
A friend's 4020 had this problem if not started daily. With the cables removed, I measured 420 ohms to ground from the starter post. Took it all apart, cleaned & varnished the field windings & then taped 'em with fiber glass tape & varnished again. Now measures more meg ohms post to ground than my digital meter can measure & will start a month later no problem! Generator faults to ground can do this same thing.
Is it an inherent weakness. Kinda hard to say. He's 40 years old now. By the time I was 40 I had a few things wrong with me too & my Creator made me with self healing propertites that put the tractor to shame! Sort of a matter of perspective. Still aggravating isn't it.
JD man inSD
12-17-2005 14:51:21
check the feilds in the starter it is common on the 24 volt
Bob
12-17-2005 17:41:52
 Re: Electrical Drain on 4020 Diesel Powershift in reply to JD man inSD, 12-17-2005 14:51:21
He said the starter was replaced, of course the new one COULD have bad fields, too.
The generator windings or the voltage regulator can "leak" to ground, if there's damp dirt and debris where it shouldn't be.
The key switch or light switch can get wet crap in them, and drain the battery, too, as well as a battery cable with damaged insulation, laying in wet dirt under the operator's platform.
Ken in Mich
12-17-2005 18:32:33
 Re: Electrical Drain on 4020 Diesel Powershift in reply to Bob, 12-17-2005 17:41:52
What I did was to cut the battery cable, and put on a cable connector that I bought from a welding suppy. When I'm done with the tractor, I just unplug it.
buickanddeere
12-18-2005 10:21:23
 Re: Electrical Drain on 4020 Diesel Powershift in reply to Ken in Mich, 12-17-2005 18:32:33
That fix has to be done on the side that's running down. I hesitate to have a machine around with a known short in a wiring harness. They tend to have electrical fires more often than equipment with intact wiring harnesses.
Ken in Mich
12-18-2005 15:23:24
 Re: Electrical Drain on 4020 Diesel Powershift in reply to buickanddeere, 12-18-2005 10:21:23
There is a couple ways to find which side is leaking. I pulled the non-ground side of each battery and put an ammeter in series. My very minor leak, I don't remember the ma, was on the starter side. There is only the one cable going there so it made sense to me to make this fix, rather than replace/rebuild the soilnoid or starter. Another reason I did this was I would shut down the tractor and forget to turn off the key, this would just about kill the battery over night. The privious owner put on a one-wire 24V alternator, and there is a draw there if the engine is shut down and the key is on. I dont know if this is normal or not.
buickanddeere
12-18-2005 16:54:01
 Re: Electrical Drain on 4020 Diesel Powershift in reply to Ken in Mich, 12-18-2005 15:23:24
The one wire alternator sounds like the culprit. There is likely a hard bond to chassis on the -12V and the 24V output is tied to the +12V. It will work but a two wire isolated 24V generator or alternator would be better. I like the idea of a battery isolation switch on every machine. If used they reduce the number of fires or dead batteries if kids are tinkering with switches.
