3020 not starting
Ben Costello
12-16-2005 18:06:33
our 1964, 3020 Diesel has problems sometimes not starting, There was a recent clutch job to the tractor and i have a sneaky suscpicion the problem may have to do with a sensor in which the tractor only starts in neutral or park(Synchro Trans.) has anybody had any issues with this and how do i get at it to resolve the problem, it was also just converted to 12volt system also.
msb
12-16-2005 21:22:03
 Re: 3020 not starting in reply to Ben Costello, 12-16-2005 18:06:33
Neutral switch is on the right side of the transmission case,behind the battery.The harness simply plugs on to the two buttons on the switch.Slip the connector off and check the switch with a continuity tester or volt/ohm meter to see if you have current flow through the switch with the transmission in neutral.If not then remove the switch and take off one shim on the switch and retry the test.There is also a quick disconnect in the wiring to the switch on the starter solenoid.It might not have gotten reconnected good.Its a couple yellow wires paired together. Check this first.
