4020 short
manitoba
12-16-2005 17:33:17
A neighbor of mine recently split his 4020 tio replace the clutch.Now when he goes to startit it blows the fuse uned the consul.Turning the key to the first indentation is O K the warning lights come on.Turning the key to engage the starter will blow a fuse.The starter will turn over easily if jumpered. Any suggestions?
Bob
12-16-2005 18:09:30
 Re: 4020 short in reply to manitoba, 12-16-2005 17:33:17
There's a couple of yellow wires, probably in a loom, that cross over the bell housing split area from the starter area to the neutral start swith, on the RH side of the transmission, under the floorboard, beneath the operator's right foot.
Likely, they got pinched, chafed, or damaged.
BE SURE to keep that tractor in park, while working with the starter wiring, to be absolutely certain it won't start in gear, and run over you or your's.
buickanddeere
12-16-2005 17:58:14
Gas, diesel, LP, 12V or 24V ? I suspect this is a 24V system and he has mistakenly tied a -12V or +12 line to chassis. The mid point between the batteries is where the bond to chassis is made. No where else. The 24V system "floats" isolated from the chassis.
