45 D Tran oil level
donwisc
12-16-2005 16:04:39
Checked the Tran oil today and there are two drain plugs, one horizontal at the rear and another further to the front in vert position.
Does that mean ther are two separate compartments? also there does not seem to be a oil level plug. I put a gun cleaning rod down thru the filler hole and got approx 8 inches of oil. Seems like this should be plenty and maybe its overfull.
Any comments would be appreciated.
Glen in TX
12-16-2005 23:48:42
 Re: 45 D Tran oil level in reply to donwisc, 12-16-2005 16:04:39
Don, It's all one compartment and there is just a low divider to help hold some oil in front where that other plug is. Yes, you checked it right and if your D goes about 3 1/2 to 4 mph in 3rd gear you have the large 41 tooth gears and oil should measure 6 1/2 to 7 inches, about 7 gallons. If your D runs a little faster than that in 3rd or you see evidence of some decals on trans about 35 tooth gears then you want 7" or 8 gallons. Some Ds and DIs also came with 28 tooth gears and need oil 8" deep or 10 gallons. Not available for the styled D but was available for the unstyled D were 24 tooth gears needing even more oil. Needless to say if you have the smaller gears go with the GL-1 140 oil for less leaks.
johndeerewoody
12-16-2005 19:30:22
There is two drain plugs but only one compartment. You did check the oil properly. There should be approximately 7 inches of oil in the transmission. 8 inches would not hurt anything. Good job.
