How to check fuel gage on 2020 diesel
Gray M
12-16-2005 13:48:10
The fuel gage on my 2020 has stopped working. It reads past full no matter the amount of fuel in the tank. The gage is the 3 wire type. Does anyone know of a simple way to check to see if the problem is the gage or the sending unit? If I ground the sending wire, gage stays on empty, but when I disconnect sending wire, the gage reads full. thanks in advance
JStacey
12-16-2005 15:56:13
 Re: How to check fuel gage on 2020 diesel in reply to Gray M, 12-16-2005 13:48:10
You answered your own question. Before you install a new sending unit, ground the new one and hook it up to test your gauge to see if it is sprung.
John T
12-16-2005 14:54:27
Thats too new of a tractor for me, but its my best guess If the gauge can be made to fully deflect between Full and Empty, depending on if the wire to the sender (or the sender) is dead grounded or open, THE GAUGE IS FINE AND THE PROBLEM IS EITHER THE SENDING UNIT IS BAD OR IT ISNT GETTING A GOOD GROUND (To the tank or its own lil ground wire)
You may wanna make sure the tank is well grounded or if the sender has its owl lil ground wire terminal, that its connected to a good ground.
John T
