HA engine for 45 combine
Eric Deci
12-16-2005 04:45:57
I am still hunting for a block or an engine for my EB45 combine. Its a 68 model per the serial #. I am in Central NY. I don;t actually know if the 4 cyl gas in there is a Hercules or a JD design, but it starts with HA (numbers are worn)and one of you fellas told me I am looking for the HA-165.... No luck at Wengers or other salvage dealers so far. Thanks!
msb
12-16-2005 21:38:34
 Re: HA engine for 45 combine in reply to Eric Deci, 12-16-2005 04:45:57
It could be either a HA 165 or a HA 180 depending on the serial number break of the combine.I am looking at a 180 Power unit Service Manual. One sure way to identify what engine it is : the HA180 has balancer bars along both sides of the crankshaft.The Ha 165 does not. It definitely is NOT a Herc engine.
Leroy
12-17-2005 13:33:34
 Re: HA engine for 45 combine in reply to msb, 12-16-2005 21:38:34
I have been it touch with him by email and it is the 180 engine as his has the double V belt drive instead of the flat belt drive used with the 165 engine
jdemaris
12-16-2005 16:13:43
A friend of mine has the same 45 EB combine here (also in central NY - Otsego Co.) It's a Hercules engine.
(Hercules JX4 - CA 3 3/4 x 4 1/4" 4-cylinder flathead engine). I think that's around 187 cubic inches. I've come across those engines many times in this area - I'm sure one could be found. They were used from the 50s to the mid-60s in all kinds of equipment - e.g. Hyster forklifts, Chicago-Pneumatic air-compressors, generators, several makes of tractors, etc. You might try Mcfaddens if you're in this area - but if he does have one, he won't be cheap. I've seen several get scrapped, I've also had several chances to buy running combines in the $500 range. Another option might also be a Continental of the same bolt pattern and horsepower - they are still pretty common. Usually, the bolt-patterns on the Continentals and Hercules are a standard SAE pattern. The Deere engines do NOT use the standard as far as I know. The later 45 engines along with 1010 and 2010 tractor engines use the old Deere two-cylinder engine bolt-pattern like that used in 420s, 430s, etc.
Dirtjockey
12-16-2005 07:38:19
We have a old 45 round back with the engine still in it. Would that work? I know after we got it the cast crank broke and we put in what looked like a forged one. Any way it didn't run to bad a hundred years ago..LOL.. I would still think the block would be good...
Eric and Natalia Deci
12-16-2005 12:28:26
 Re: HA engine for 45 combine in reply to Dirtjockey, 12-16-2005 07:38:19
from what everyone tells me, that roundback engine is not correct for my setup, unfortunately!
Leroy
12-16-2005 06:19:31
If you posted before then I missed your post. What happened to your engine? the 180 engine is a wet sleeve engine while the 145-165 engines are deck plate engines that are completly hollow block with the sleeves all molded into one piece with a 1/2" plate at the top of the sleeves and that block should be easy repaired if cracked. I have the parts book for the machine and both 145 & 180 engines and the operators manuals for the Hi, Hi-Lo, early square back and late square back. If you send me the serial no of your machine I could tell you better what engine you have. Leroy
Leroy
12-16-2005 05:48:46
That year EB should have the HA-180-G engine I am thinking, If it has the double V belt seperator to engine drive then it is the 180 cu engine. If by chance it has a 4" wide flat belt drive instead of the double v belt drive then it is the 165 engine that looks exactly identical to the 145 engine used on the round back HI-LO machine and the Hercules that would only be a flat head engine used on the verry first Hi round back machines built back around 1957. If yours has a flat belt drive it would be about a 64-67 model instead of a 68 model. I have machines here that are 62&63 with the 145, 65 with the 165 and a late 69 with the 180 engine and the innards on the 180 (dont know if the block is the same) but are the same as a 2510 tractor and the 145 & 165 engines will bolt right into the 1010 and 2010 tractors and I know of two places, possibly 3 within about 40 mile that may have that engine as the 45 was a very pouplar combine around here. If you want addresses email me at [email protected]
Steve Crum
12-16-2005 05:01:03
You can preety much bet it is a Deere engine. I have an HA-115 engine off a model 40 combine that is set up on a stationary 12 KW generator. This is one sweet running engine (last time I ran it) 7 years ago. The 115 engine is rated at 42 horsepower, so I suspect the 165 is likely in the 60 horse range. I plan on selling the engine and generator eventually and getting a Miller engine drive welder with a 10 KW generator.
Originality aside, I have seen some of these midsized combines refitted with GM or Ford inline 6 cylinder engines, usually fitted with a Pierce govener.
Eric Havens Deci
12-16-2005 06:32:11
 Re: HA engine for 45 combine in reply to Steve Crum, 12-16-2005 05:01:03
If I had half a brain and the equipment, I should put in a stronger motor, I have heard the 45 struggles with the 2 row corn head. Maybe the chev 454 I have laying here!!! Thanks for the info, anyway - the inline 6 idea, if I could find somebody who did it and can explain the bellhousing part, would be WAY cheaper than anything I have seen yet. One guy wanted 500$ for a dirty old block that I would have to send fo rmachine work.
