4020 transmission shift problem
deeredoug
12-15-2005 19:42:51
can not shift the lever into reverse also the tow lever moves freely like it is not connected to any thing the transmision seems like it is locked or in park.Pulls the engine down when you release the clutch
Thanks in advance for your comments
deeredoug
msb
12-16-2005 21:49:52
 Re: 4020 transmission shift problem in reply to deeredoug, 12-15-2005 19:42:51
I have seen the shift lever break right at the weld on the pivot point.The part that pushed the cable down.Its under the cowl.You can assume what you want about Bob ,but I can tell you he is one of the best informed people here when it comes to Deere tractors.Also sure your post didn't come across the way you intended.
tractorfixer
12-15-2005 19:54:08
I've seen the park cable so bad that the park pawl stays engaged. So you're trying to have the tractor in gear and in park at the same time. Take off the RH battery cover and the cowl cover and see if the linkages are moving. Are the arms moving on the shift valve? Is the park arm rotating when the gear selector is pulled into the park position? Good Luck.
deeredoug
12-16-2005 19:38:21
 Re: 4020 transmission shift problem in reply to tractorfixer, 12-15-2005 19:54:08
Answer to (Bob)I assure you that I know the difference between a syncro transmission and a power shift,I realized now that I refered to the clutch,In the operators manual it is refered to as the inching pedal. My thanks to tractorfixer
his proposed fix is a very valid fix, I will pull that cable and see if it is bad. I have seven 2 cylinders,So i am not to sharp on one that has this many cylinders,
Thanks a lot deeredoug I have learned a lot from
these forums on ytmag there are many members who have been most helpful
Bob
12-16-2005 23:28:26
 Re: 4020 transmission shift problem in reply to deeredoug, 12-16-2005 19:38:21
third party image
Sorry for trying to help!
deeredoug
12-17-2005 10:44:57
 Re: 4020 transmission shift problem in reply to Bob, 12-16-2005 23:28:26
Bob and the forum operator, I am sorry if I offended any one with my return response.I was just stating the symtoms of the problem.I do know what kind of transmission is in my tractor,I
now know that I used the wrong termonlogy in discribing the inching pedal as a clutch,when depressed it disconnects the engine from the transmission.How ever I am humbled by Bobs last post I value the responses I receive thru this forum and will continue to contribute . (the only mistake I have made in 79yrs)
deeredoug
deeredoug
12-16-2005 19:31:37
deeredoug
12-16-2005 19:30:15
Bob
12-15-2005 21:37:20
Don't know what he has, but only the powershifts use the cable.
If it's pulling the engine down when he releases the clutch, it sounds like he has a Synchro, and there is a broken shift for and/or the sychros have worn and gotten out of place, preventing shifting, and it's stuck in two gears at once.
