430 and MT
Brian Ray
12-15-2005 09:53:13
Will a MT engine bolt in to a 430? Are the engine and drivetrain parts interchangeable? Are any parts the same. If not, what is the difference?
CPeter
12-15-2005 19:25:56
 Other way round in reply to Brian Ray, 12-15-2005 09:53:13
I have a friend the has one the other way round, an M with a 420 engine in it. As Wayne said, you really need everything from the bell housing forward. They will bolt up at the bell housing, though.
CPeter
Lavoy
12-15-2005 15:48:41
 Re: 430 and MT in reply to Brian Ray, 12-15-2005 09:53:13
Like Wayne said, the engine will bolt up, but the radiator, fan assembly, and air cleaner will all need to be changed to the one from the MT. I would also believe that the throttle rod bracket from the top of the water outlet would have to be used from the MT. The MT will not have provision for mounting the coil on the valve cover, and probably a host of other things that you would encounter.
Why not fix the engine you have, or get the correct engine?
Lavoy
buickanddeere
12-15-2005 15:35:40
Not feasable. It's like cutting up a good pair of pants to make a patch for an old pair of pants.
Wayne in Tn.
12-15-2005 13:54:53
I would say the MT engine will physically bolt up. But it will not have provisions for the water pump. It would have to utilize the "percolator" type cooling and you will need to use the MT fan mounting assy.
