JD 4010 Smoking Wires
norman alan
12-14-2005 21:26:34
Hi,
After few weeks off I tried to start my old JD 4010 Diesel, but it will not start I heard a sound in the engine and smoke coming from the battery cable so I stopped.
I recently rebuild the full injectors pump and new full filter. Also I replaced stage 1 & 2 filters.
This engine usually starts with �engine starter� but not this time. The engine turn but will not fire until I got the sound and smoking wire�
Any idea what shall I try to do? Last time it started I let it run for � hour and then turned off.
donmyeil
12-15-2005 13:29:56
 Re: JD 4010 Smoking Wires in reply to norman alan, 12-14-2005 21:26:34
Smoking wires means bad connections or shorted wires, or a combination of low voltage. 30 min wont recharge the batteries if you crank very long. Recheck the wires on the starter.
norman alan
12-15-2005 14:10:25
 Re: JD 4010 Smoking Wires in reply to donmyeil, 12-15-2005 13:29:56
I did that this morning but still will nopt start I got full all the way to the pump but no full after that..I may replace the pump unless you have another idea? any recomendations on doing that? I do have another re-build one handy but never tested yet. god bless
norman alan
12-15-2005 20:13:51
 Re: JD 4010 Smoking Wires in reply to norman alan, 12-15-2005 14:10:25
sorry I meant that the fuel tank is full and I pumped the fuel all the way to the pump. it is not the fuel as it is new and the air out from the system. I have solar battery charger I keep it on this tractor to keep the battery charged.
Tx Jim
12-15-2005 04:15:26
Norman,has engine run since fuel system was renewed? Was all air purged from fuel system? Tx Jim
norman alan
12-15-2005 06:36:04
 Re: JD 4010 Smoking Wires in reply to Tx Jim, 12-15-2005 04:15:26
Yes..I done all of that also I rebuild the starter
norman alan
12-14-2005 21:39:33
third party image
This is my 4010
Link
Link
Link
