Battery for JD G
hahter
12-14-2005 16:27:23
I have a 50 Model G with .125 over-sized pistons. I am having a problem starting the tractor. I am going to replace the cables to starter and ground. I was wandering if I take 2 750 cca batteries and hook them in parallel would that be to much for the starter and the electronic ignition.
DickD
12-15-2005 23:17:04
 Re: Battery for JD G in reply to hahter, 12-14-2005 16:27:23
If the getting on and off to shut the petcocks bothers you,I saw something pretty neat one G owner had done. He turned the petcocks so he could braze a piece of rod to them, and ran it up to the light bar. Then he made brackets to hold the rod and bent the end in an "L" shape, enabling him to open and close the petcocks from the seat. It works well and doesn't make the tractor look tacky.
GPULLER
12-15-2005 09:37:43
One 750CCA battery should start your G without opening the petcocks. My G is .090 over and has 135psi of cylinder pressure and works just fine with one battery of that size. I would suggest getting the starter checked out and update the cables.
hahter
12-14-2005 18:39:52
The tractor runs and starts fine, I just wanted to be able to crank without having to always open petcocks. The ground is connected to the the power-trol housing at rear of tractor. The starter seems fine I had the starter apart when I had to replace the bendix drive when it stripped out when the tractor back fired. The backfiring has been fixed, caused by distributor being retarded too much. Thanks for the help.
G/MAN
12-15-2005 07:16:33
 Re: Battery for JD G in reply to hahter, 12-14-2005 18:39:52
If you have hi-comps in it, you'll want the petcocks open when starting it. The .125 over isn't a big deal, but the compression increase is. Opening the petcocks will save a lot of wear and tear on the starter, ring-gear, etc.
G/MAN
12-14-2005 16:35:56
That shouldn't hurt the starter or ignition in the slightest. 12-volts in parallel still give 12-volts, so the ignition isn't going to care, and the amps drawn by the starter are pretty much dictated by the starter itself, so the batteries can't "send" more juice than the starter can take. Just use good quality cables of sufficient size and good soldered-on or crimped-on connections of good quality. The cheap "bolt-on" ends are nothing but a problem waiting to happen. Also make sure your ground cable is connect to a good chassis ground and that if you're connecting it to the battery box, the box is well-grounded to the rest of the tractor. Personally I'd ground the batteries directly to the main case somewhere, and make sure you have a good clean connection. It's also probably not a bad idea to get the starter checked out to make sure it's up to snuff. Also, making sure the engine is in a good state of tune - carb adjusted properly, choke working correctly, timing correct, etc. - will reduce the amount of cranking time needed.
