3150 leaking load control shaft
DavidG
12-14-2005 14:31:11
All summer long the load contol shaft is leak-free. With cold weather, the shaft seals leak while sitting cold, stops leaking when warmed up. It has a new shaft and seals. Any suggestions? It really leaks alot while sitting.
Thanks for your help.
JStacey
12-15-2005 17:56:44
 Re: 3150 leaking load control shaft in reply to DavidG, 12-14-2005 14:31:11
Does the 3150 have bushings in the case? If it does hopefully they replaced them. If they did not then the seals could be stretched a bit.
G/MAN
12-15-2005 10:42:55
I'm not familiar with the load shaft seals on those animals, but is it possible you've got some out-of-spec parts that are causing the problem when they're cold and shrunk down? I'll check the 3150 parts book and see if I can see anything else. I don't think we have any manuals for those.
