JD 5220
Shy
12-14-2005 13:28:28
Looking to buy a JD 5220.. I have a 5 acre hay field I work...will this tractor do what I need it to??? Run a MF#3 square baler....plow and disk if needed??? Just want to make sure I have enough tractor.
Shy
12-14-2005 18:56:44
 Re: JD 5220 in reply to Shy, 12-14-2005 13:28:28
Thanks for all the info! I just wanted make sure....I am very close on the purchase!
burnetma
12-14-2005 18:17:28
I happen to have a JD 5420 and a MF#10 baler. The JD 5220 will easily run the baler. Really only need a 25 or 30 HP tractor to run that baler. A square baler will not over-tax a 5220 under most circumstances. It will limit your choice of mowers. You will likely have to use a 7 foot haybine, but that is OK for your small acreage.
Depending on soil type, a 3 bottom plow should be no issue. MFWD will add 25% more traction and probably get you into a 4 bottom if properly ballasted.
Honestly, that is more than enough tractor in my opinion.
leon
12-14-2005 18:08:57
I'm not shure what a MF #3 baler is, but I presume it's the old standard small rectangular bale, not one of the new big monster bale makers. If that's the case, you'd probably be over tractored for 5 acres of hay with a 5220, but that's a good way to be!
