50 Carb
Bill46
12-14-2005 04:44:59
Started and ran my 50 last night. Had not run it for awhile so figured it needed to be warmed up.
As always...it was a little had to start...have to be careful I don't flood it.
Once running I let it warm up and noticed the carb was leaking fuel. It looks like the gasket where the bowl mates to the carb is leaking.
I have been told to be very careful how I remove that big nut or I will tear something up...nut or the casting. I ordered a bebuilt kit, but how do I get that nut off? I have never tired this before on a green machine. Any help is appreciated.
John Van Valkenburgh
12-14-2005 17:55:06
 Re: 50 Carb in reply to Bill46, 12-14-2005 04:44:59
Bill,
You've got lots of good responses to your question. I'm told that Robert's is the place to go for John Deere carb work and parts. I was thinking about sending the carb for my 50 to him pretty soon as the throttle stem bushings are leaky and I don't have the proper reamer to fit new ones. He also bench tests the carbs he rebuilds.
The only thing I might add is that your 50 should not be a hard starting beast. If your battery is in good shape and your cables are clean and tight and the ignition system is properly adjusted and the carb is properly adjusted it should crank up within 2 cranks of the flywheel. If your 50 floods easily it may be that the float is mis-adjusted and allows too much gas into the carb bowl. A leaky float will "sink" and cause the same problem.
Best of luck. That 50 is a great little tractor.
John
1953 Model 50
Bill46
12-15-2005 04:27:20
 Re: 50 Carb in reply to John Van Valkenburgh, 12-14-2005 17:55:06
Thanks John. By the serial number mine is a 53 also.
Duane Larson
12-14-2005 06:19:40
Bill46,
If your 50 has a duplex carburetor (the early all-fuel engines have a one barrel), the fuel level is right at the bowl-cast body interface. The nut holding the bowl on is brass, with a hole through the center to accomodate the metering screw adjustment. If this is the carb you have, the nut will likely come off with a "reasonable" amount of pulling. As Mike noted, because of this fuel level people try to tighten the bowl nut to reduce leakage and too long a breaker bar can break the stem.
When you put it back together, I always use an additional soft fiber washer on the stem - they came with the washer inside the bowl, not the outside. I put one in each place. Be sure to check that the bowl is fairly straight across the bottom side or it will not fit tightly against the body/bowl gasket when pushed up with the bowl nut. They are often bent because folks put the neck gasket on the outside of the bowl and when tightening, bend the bottom of the bowl. It can be straightened by some careful pounding.
Pat is correct - Bob Beaver has good carburetor repair videos - you will need the one for duplex carbs. www.robertscarbrepair.com will show them (and the second gasket for the neck).
Bill46
12-14-2005 07:30:39
 Re: 50 Carb in reply to Duane Larson, 12-14-2005 06:19:40
Thanks ...I am new to this 2 cylinder stuff. But you guys are leading me in the right direction.
Mike M
12-14-2005 05:02:51
I don't think "off" is the problem. Trying to stop a leak by tightening them up is, as they will break off if overtightened.
P Browning
12-14-2005 04:52:55
Bill -- Believe it or not, there is a fellow out there --Robert Beaver at Robert's Carb Repair who just loves to talk and help people such as yourself with carburetor and magneto grief. He will encourage and guide, and (of course) sell you parts & tools you may need. I am not eminently familiar with the carb you have, but I suspect Robert will be. www.robertscarbrepair.com or you can call him (712) 262-5311. He also sells carb repair videos that are fairly good -- if you buy, go for Carb 2 because is was made later, and for my money -- was a better video.
