Installing seals on injectors on 4030
Willy P
12-13-2005 18:53:06
I can see some compression leaking out from the injectors of my 4030 and I guess that I need to replace the seals on the injectors,how do you replace them little o-rings at the bottom of the injectors? Thanks
jdemaris
12-14-2005 05:23:08
 Re: Installing seals on injectors on 4030 in reply to Willy P, 12-13-2005 18:53:06
The tool made for replacing the seals is # 16477. That's a Roosamaster number, but Deere used to sell the tool under the same number. It looks like a little thimble and you can replace the seals without it - or you can make your own tool easy enough. You need something round and tapered, small enough on one end to get the seal started on, and on the other end the same diameter as the injector nozzle shaft. The main concern is not to stretch it any larger than absolutely necessary. Keep in mind those seals are teflon - and once you stretch them, they are, difficult to get back to size. When I install them, I first heat it in hot water or equivalent, then push it on, and then let it sit over-night to give it time to return to its original size. It is also likely, that since your injectors are leaking, the bores in the head are sooted up and need to be cleaned out before you re-install the injectors.
Mike Aylward
12-14-2005 09:41:37
 Re: Installing seals on injectors on 4030 in reply to jdemaris, 12-14-2005 05:23:08
I'll agree with everything jdemaris said. I will add that in a pinch the bottom of a ball point pen (the old screw together type) is almost exactly the right size to use for this. Cut off the threads of the pen and your gradual taper and the right size outside diameter is right there. You can then slip this "tool" right over the injector and slide the seal right into place. The hot water is necessary to make the seals pliable. They will break in two if this is not done and/or will not shrink to original size. And if they are too loose on the injector they will slice as you install them negating what you are trying to get done. Hope this helps. Mike
G/MAN
12-14-2005 10:24:14
 Re: Installing seals on injectors on 4030 in reply to Mike Aylward, 12-14-2005 09:41:37
I don't do much with pencil nozzles anymore, but never used the hot-water trick, and don't recall splitting any, but you do have to wait for them to shrink down some. I know I've never had the luxury of being able to wait overnight for them to shrink back down. Most I replace are in irrigation engines in the middle of August, usually when the pivot is in the middle of a turn.
