1950 B Generator/Regulator Wiring
JDRookie
12-13-2005 18:21:10
I had the generator rebuilt on the B and forgot to mark where the wires went! It has a 3 terminal square Delco Remy regulator. I have a white and black coming down from under the hood, (from the ammeter and lights I think) and I think that they were stacked on the Batt terminal. Does this sound right? I don't want to fry anything, and the snow is starting to fly here in Michigan! Thanks for any help.
johns48b
12-18-2005 09:08:40
 Re: 1950 B Generator/Regulator Wiring in reply to JDRookie, 12-13-2005 18:21:10
after the wires are disconnected don't you have to polarize the generator. i don't really know what that means but i know you have to use a wire and touch the terminals marked arm and field or visa versa with the tractor running. i think you only have to do this if it isn't charging right. can somebody straighten me out on this?
John T
12-14-2005 06:18:43
JD, Im in basic agreement with the CLW and Glen and heres my thoughts: If you really had TWO wires on the VR's BAT terminal, what I suspect is the tractor originally had (or was configured for) a 4 pole (BAT ARM FLD LOAD) Voltage Regulator but a 3 pole (BAT ARM FLD) was used or replaced.
Heres the deal: The 4 pole VR (BAT ARM FLD LOAD) looked like the 3 pole cuz you only see the 3 poles together up on top (BAT FLD LOAD) HOWEVER on those the 4th ARM pole is often off the bottom or another side all by itself. When using a 4 pole VR loads like lights n ignition were supplied from the VR's LOAD terminal so they had not one but two wires up to the dash, one to the ammeters load terminal and the other to the switches BAT input terminal. A 3 pole VR (BAT ARM FLD) had but one wire to the dash, to the ammeters load terminal. On a 3 pole VR loads got fed off the ammeters load terminal instead of off the VR's L terminal.
Sooooo ooooo see if the VR you have is labeled BAT ARM FLD and theres no bottom ARM terminal OR its labeled BAT FLD LOAD and theres a hidden ARM terminal down underneath????? Regardless what you have it can still be wired to make it work.
Take a test lamp and see which wire coming down from the dash IS ALWAYS HOT?? That wire MUST connect to the VR's BAT terminal REGARDLESS. Then my guess tells me if the other wire down from the dash is left disconnected THERES NO LIGHTS OR IGNITION POWER!!! Sooooo ooooo if all you have is a 3 pole VR (BAT ARM FLD) go ahead and piggyback that other wire from the dash onto the VR's BAT terminal also ands the lights n ignition ought to work then.
HOWEVER if youre new VR is a 4 pole, wire that other "not hot" dash wire to the LOAD terminal.
I guess the bottom line is if the new VR is a 3 or 4 pole???? but if only a 3 pole and you pigtail the hot wire from the ammeter and the feed wire to the switch on top the BAT terminal she ought to work. Just be sure the other wires are correct: FLD on VR to the gennys Field post and ARM on the VR to the gennys ARM post.
John T
CLW
12-13-2005 19:07:56
IF, IF, IF it is still wired the way it left the factory the BLACK wire from the ignition goes to the (L). The WHITE from the ammeter goes to the center (unmarked) contact and the (F) shows to be a short wire that is grounded to the generator. This is for serial number 201000-up. This is out of the Deere Electrical Systems manual SM2029. May be a good idea to let someone back me up on this before you do it.
CLW
Glen in TX
12-13-2005 21:52:14
 Re: 1950 B Generator/Regulator Wiring in reply to CLW, 12-13-2005 19:07:56
CLW has that right from the SM2029 manual but I also see a note I didn't remember so yours could have had both the white and black stacked on the bat. terminal? The note points at both black and white wires on L and BAT terminals saying "When 1118786 regulator is substituted for 1118305 CV regulator , attach these wires to regulator BAT terminal." So...it may depend on which regulator you have and shows the same note for A,G, & R. I'm not sure right now what the difference was in those regulators?
JDRookie
12-14-2005 14:31:20
 Re: 1950 B Generator/Regulator Wiring in reply to Glen in TX, 12-13-2005 21:52:14
Thank you gentlemen. From what I can tell, yes, the two wires do go to the bat terminal. I started it and the ammeter is showing that it's charging the battery, but, I still don't have any lights. This might be a totally unrelated problem. When I touched the white wire to the L terminal, it arced. Anyway, thanks again for your help.
Glen in TX
12-14-2005 15:04:35
 Re: 1950 B Generator/Regulator Wiring in reply to JDRookie, 12-14-2005 14:31:20
I saw John T got you all straight on regulators. Yes, the later replacement regulators would have been the one with 4 terminals. If you need a wiring diagrahm shoot me a email later. Black wire to light switch. White wire to ammeter. Make sure the light switch output terminal is hot when on with a test light and that the switch isn't just bad.
