'50 A-Clutch pulley, chunk is
njs
12-13-2005 08:52:27
missing. Outer edge has a right angle pc of steel that looks broken off. Then I saw a picture of someone's pulley that had the same chunk missing. Can someone explain?
Thanks
Ben.So.Tex.
12-13-2005 17:38:24
 Re: '50 A-Clutch pulley, chunk is in reply to njs, 12-13-2005 08:52:27
Someone may have tried to remove the disk driver with a puller and popped a peice of it off.
They should be removed with two bolts and square nuts.
You may want to find a replacement for it if possible so your engine will stay balance,their is also a V on the crankshaft and one on the driver that need to be lined up or the tractor will shake while running. someone else may offer you some advice. Good Luck Ben
