JD 4240 clutch
walterinbr
12-13-2005 07:04:25
How difficult is it to replace the clutch in a 4240? Mine is still moving but just going slow with no power.
G/MAN
12-13-2005 07:16:24
 Re: JD 4240 clutch in reply to walterinbr, 12-13-2005 07:04:25
Power Shift or Quad-Range? You need to have trans system and lube pressures checked either way before jumping to the conclusion that it's a clutch problem. Quad-Ranges use a hydraulically applied Perma-Clutch wet-disk clutch pack, which requires the tractor to be split for replacement. Special tools are also required to set up the clutch when reassembling. Power Shifts use a dry-disk torsional damper on the flywheel to drive the clutch pack mounted in the front of the transmission. The damper can slip, usually as a result of a leaking rear main seal. That obviously also requires a split to replace.
