Frankenstein A JD back on the operating table.
Randy Varilek
12-12-2005 21:42:44
I have a 1952 A JD that we beefed up for loader work about 10 years ago and she back on the "operating table". She weighs 10,500 lbs without the loader. It has the wide front off of an 8010 AC on it with orbit steering. the rear rims are widened 8" with 15.5-38 loaded tires. We originally set it up because we needed a cheap loader tractor and we had several old A's. She has served us well but recently lost reverse moving snow and was getting due for an overhaul. Instead of rebuilding the trans, I bought a "60" for parts and stripped it down to the main case and bolted it to the A rear end. so far it looks like everything will bolt up except the frame needs 2 holes drilled and tapped. But when I get done, the old girl will have live pto and hydralics to boot. I'll keep you posted and let you know how it turns out.
Randy Varilek
12-13-2005 22:56:11
 Re: Frankenstein A JD back on the operating table. in reply to Randy Varilek, 12-12-2005 21:42:44
The big reason for not using a complete 60 is I don't already have one but, I do have 8 A's and only a partial 60 that i picked up for parts a couple of years ago. Also, I highly doubt that the 60 powersteering would turn the 11l-16 i have on front with a ton of bale in the air. When I get it put back together I'll try to get some better pictures but I'll post the only one that I have of her.
F-I-T
12-14-2005 10:59:51
 Re: Frankenstein A JD back on the operating table. in reply to Randy Varilek, 12-13-2005 22:56:11
"Also, I highly doubt that the 60 powersteering would turn the 11l-16 i have on front with a ton of bale in the air."
Ooooooh!
I bet she would! I've turned the front wheels (two 6.50x16's) just fine with a load of black sloppy bog filth on my too big a bucket 45 loader when those wheels were sunk in the muck. Wouldn't recommend it, but those were strong units in their day. There's a whole lot more torque than a Charlynn or Behlen motor trying to turn it from the steering shaft side!
Frank
Maark
12-13-2005 12:47:09
Bill Zeggers in Newton Iowa already bolted a 60 transmission to A frame rails. Not a new idea.
DaveH IA
12-13-2005 14:00:24
 Re: Frankenstein A JD back on the operating table. in reply to Maark, 12-13-2005 12:47:09
Bill"s A60" as he has it decaled, looks different which is what he wanted. He has a 60 and an A--now he has an A60.I worked for Bill and his partner, at there dealership,from 1972 till 80.
720Deere
12-13-2005 12:55:49
It sure would be easier to just buy a 60 with powersteering and be done with it. I don't see any advantage to a "half & half" A/60.
55 50
12-13-2005 17:10:10
 Re: Frankenstein A JD back on the operating table. in reply to 720Deere, 12-13-2005 12:55:49
720Deere, I agree.
parrothead
12-13-2005 05:50:53
Sounds cool. Let us know when you have a photo ready. I can't wait to see it.
JD9295
12-13-2005 01:05:31
better yet, post a pic when your done. a pic is worth a thousand words.
is she scared of fire???
