JD 4630
mross
12-12-2005 16:55:20
Hi I'm looking for a tractor in the 150 HP range and I have seen a couple of 4630's around. They seem like a good deal for the amount of horsepower. What is the general opinion on them? Have there been any problems with the engines or anything else? Any help would be appreciated.
Thanks
MR
JD man in SD
12-15-2005 18:14:02
 Re: JD 4630 in reply to mross, 12-12-2005 16:55:20
all the problems wilamayb talks about on 4630 are real common on tractors turned up to that much HP if you put one to work using that power all day long it blow tubo at about 100 to 150 hours at 200 to250hr the pistons will crack above the pins been there done that a good rule of thumb on turning up HP on diesel is not over 10%
ejr-IA.
12-13-2005 10:33:51
I still have two of them 76and77 .I like the wt. and ride both are around 180hp I updated the turbos which helped their power curve at lower rpm.Their quaderange with 18.4x42 radials.The only real problems is the axles walking out of the houseing had to have them updated.Also did under hauls around 6000hr. mains rod bearings.
wilamayb
12-12-2005 20:24:21
4630's are OK tractors. They are bulky for their horsepower, and have an appitite for diesel fuel (more than likley wont make it 8 hours under full load). They are hard to start if the temperstures get much below 50 degrees. (sad but true). If you are looking for cheap horsepower the 404T with aftercooler will take a lot of overfueling. Our 4630 made it to around 8000 hours at 210 horsepower. The rest of the tractor is built for pulling, and is fairly reliable and will withstand the abuse. It has all of the other JD row crop problems. If fitted with a syncro-range trans mission it will be hard to shift and easy to cross up. If it is fitted with a quad-range it will jump out of B range. The 404T has very little low end lugging capabilities. If it is below 1500RPMs it wont pull steam off a hot fart. The 4440 will do just about as much work for less fuel and 466 is a much more reliable engine with better fuel economy, better cold starts, and better low end pulling capabilities. The 4640 is also a good option. They also have the better engine, and seem to have a better all around feel in the seat. The 4640 will also have a better seat than the 4630 if it is equipped with the optional hydraulic spring assist seat. Its all in what you want. The 30 series are allright in a pinch, especially if it is cheap. All tractors in that age and price category are more than likey in need of some repair, so just get ready.
