Found a 4630 engine for my 4520.... couple of Q's
Shane S
12-12-2005 09:37:39
OK guys.... I've found a 4630 engine for my 4520. Thing is my tractor has a recently rebuilt clutch in it and I would like to keep it if possible. I was wondering about the interchangability of the flywheel/clutch assembly. Should I just keep my flywheel, and if so, will it fit on the 4630 engine. My flywheel only has 4 bolts, and from what I have seen, the later 404T's should have 6 bolts?????
My engine's numbers are as follows: 404TRA 248102R.
One other concern is the damper. Is it the same also? Do all the 404's bolt to the hydraulic pump the same. Mine has two rubber grommets that are joined by a split piece of aluminum with two bolts. Is this the same system as used on the 4630 engines?
Any advice would be greatly appreciated.
Thanks,
Shane
G/MAN
12-12-2005 13:20:52
 Re: Found a 4630 engine for my 4520.... couple of in reply to Shane S, 12-12-2005 09:37:39
Flywheel and clutch should swap over to the later engine. Your dealer should be able to find you the 1/2" plugs they screw in a 6-bolt crankshaft when using a 4-bolt flywheel. The front damper and pulley seem to be specific to the 4520/4620, but I believe those dampers should mount to the 4630 crankshaft. I guess that will depend on your pulley setups, but yes, the 4630 uses the aluminum couplers as well, and they're the same part number on both tractors. The actual pump drive shaft is not the same as used on the 4630 - probably a different length. Probably not a bad idea to simply replace the damper, as Deere usually recommends damper replacement at 4500 hours.
ejr-IA.
12-12-2005 12:20:11
I've split my late model 4630 and it has 4 bolts and a guide pin should be the same and the cranks I think will interchange.466 have the 6 bolt.I know of several 4020's runing 466 engines around here,mostly for pulling.
